Cloning Blu-ray movies on Mac computer? Yes, you are not talking insane, because cloning Blu-rays on Mac is not something like rocket science. On the contrary, with a Mac Blu-ray cloner software, it is super easy, you can do it with just a few more mouse clicks. DVDFab Blu-ray Copy for Mac is such a software which can help you clone a Blu-ray movie from disc onto Mac HDD as ISO image file or onto another blank BD disc.
Having interest to see how that could be realized? Just check this tip out:
Best Blu-ray Cloner for Mac > Step 1: Download and install the latest DVDFab 9 for Mac onto your computer;
Best Blu-ray Cloner for Mac > Step 2: Launch DVDFab 9 for Mac, choose Copy option in Option Bar, and then put the Blu-ray disc you want to clone into the external Blu-ray drive;
Best Blu-ray Cloner for Mac > Step 3: Select Clone/Burn mode on Mode Panel, and then press the “Start” button to let go the burning.
Best Blu-ray Cloner for Mac > Step 4: when prompted by the system asking you insert a blank BD disc into the disc tray, you just take out the original disc and put in a blank BD disc to continue the cloning process.
Note: if you want to clone the Blu-ray movie from disc onto Mac HDD, you need click the disc icon at the “Save to” section to select a directory on your Mac HDD to save the ISO file.
Software you need: The latest build of DVDFab 9 for Mac
Product you need order: Blu-ray Copy for Mac
For more information, please go to: www.dvdfab.cn/blu-ray-copy-for-mac.htm
